Hello Tagdiv team,
I have an issue with your Tagdiv Instagram widget. Some pictures don’t load, screwing up the entire layout !
I updated the theme (current version V 9.1), updated TD COMPOSER plugin, cleared all cache, tried deactivating all cache plugins, I tried setting up a new instagram widget, no fix found.
Do you know what could be wrong?
Website is live here : https://bit.ly/2bN6H2Y (instagram widget is in the footer area)
I tried with cocacola, it works fine.
But with our account, this is the result :
I tried to display our instagram feed with “Instagram Feed” plugin, it works perfectly, so, the issue comes from TagDiv instagram plugin sadly, see here the difference :
(left : Tagdiv plugin VS right : Instagram Feed plugin)
Any fix ?
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Hello i have the same problem please i need to fix it .
example 1 <——
Hi Brokn,
