When i activated tagDiv Speed Booster, i had a problem with few plugins ( Speed Booster v4.9.1 – Disabled – incompatible plugin detected: classic-editor/classic-editor.php ) like classic editor, akismet … then you suggested me to put code and i did it;
private $allowed_plugins = array(
‘bbpress/bbpress.php’,
‘contact-form-7/wp-contact-form-7.php’,
‘jetpack/jetpack.php’,
‘js_composer/js_composer.php’,
‘td-speed-booster/td-speed-booster.php’,
‘font-awesome-4-menus/n9m-font-awesome-4.php’,
‘wordpress-seo/wp-seo.php’,
‘wp-user-avatar/wp-user-avatar.php’,
‘td-social-counter/td-social-counter.php’,
‘wp-super-cache/wp-cache.php’,
‘woocommerce/woocommerce.php’,
‘td-mobile-plugin/td-mobile-plugin.php’,
‘revslider/revslider.php’,
‘td-composer/td-composer.php’,
‘td-multi-purpose/td-multi-purpose.php’,
‘td-newsletter/td-newsletter.php’,
‘td-amp/td-amp.php’,
‘sitepress-multilingual-cms/sitepress.php’,
‘td-cloud-library/td-cloud-library.php’,
‘akismet/akismet.php’,
‘classic-editor/classic-editor.php’,
‘regenerate-thumbnails/regenerate-thumbnails.php’,
‘tinymce-advanced/tinymce-advanced.php’,
Now that works, but there were some changes at my web, at my pages and blockes and i cant repair them and i cant have the look i had before tagDiv Speed Booster. Is there possibility to get back the look i had before?
thx
There are some scripts that need to be load at the beginning of pages, if you force theme ( like in above example ) your website can be broke.
You can remove the settings you made in theme file for tagDiv Speed Booster and clear all cache in this way all scripts will be load like before.
If the status look like this -> https://www.screencast.com/t/pLst5ro0VvNa that means that will work only on those plugins that are set in plugin files and there are still some plugins that are detected; if you’ll check the page source, you’ll see that some of plugins are move down.
