Recently tried to create some taxonomies…when i tried to Archieve the newly created taxonomies …it shows 404 error Any solution for this..
we have created taxonomies with the following plugin
https://wordpress.org/plugins/simple-taxonomy/
Demo Post : @ http://www.tollywoodfans.in/wordpress/legend-200-days-function-in-yemmiganur/
when we tried to browsed through taxonomies its redirecting to 404 page …Can you suggest me how to navigate through this taxonomies
Unfortunately the short time doesn’t allow me to test this plugin, you can check here for more info: https://github.com/herewithme/simple-taxonomy or to the support page of this plugin. You might also consider that this may not work properly with this version of WordPress as it hasn’t been updated since 2013-1-4: http://screencast.com/t/GAid459c
Hope this helps!
I got taxonomy created with this plugin “Ultimate Taxonomy Manager” and working fine ..
When i am trying to archive, if we observe the BREADCRUMBS
Date + year
it shows the following
Home 2014
Archives
Demo url’s :: http://www.tollywoodfans.in/telugu-movies/karthikeya/
Can u help me in creating the BREADCRUMBS just like tag arhcieve’s
Home>tags>
You can find and modify as you like the archive breadcrumbs generator function from here: http://screencast.com/t/hoRqycwTV
You could also use a plugin like WordPress SEO by Yoast to set custom breadcrumbs.
Please follow this topic I have explained there what you need to do: https://forum.tagdiv.com/topic/using-yoast-breadcrumbs/
