Problem with TD Composer after upgrade from 10.2 to 10.3.2
I updated the theme to 10.3.2 from 10.2. and TD Composer no longer works correctly.
When I edit a page with TD Composer, if I add an item and save my page, the item is added to all the pages of my site that uses TD Composer.
It does the same thing if I try to create a new empty page, the elements that I add will also be added in all other pages of the site, using TD Composer.
I have disabled all plug-ins and the result is the same.
I’m stuck here.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
