Problem with test
Sorry for my english first.
I build my website but when i use the TagDiv composer, it’s impossible to change the apparence of the text like (list, center, table). I must only use Tagdiv composer for the page but for the text, wich editor must i use ?
THanks
Helo !
For posts you will have to use wordpress; classic editor or gutenberg. TagDiv Composer Does not work on post content.
I have lot of problem, when i put some text with classic editor, after, i can’t find how to delete the full width for my text and image like this : https://ibb.co/m0LVsjQ
And if i create box with tagdiv, i can’t edit the text like i want (on the editor i only see special caraters …)
Thanks for your help
Hello !
In order to adjust the site width you have to select every row of your page using the tagDiv Composer and then set the stretch mode you want like here : https://www.screencast.com/t/BkWwdHh6
