problem with text block – background color
hi there loving the theme
just having a issue not sure if its just me.
Wanting to change the background color of the text block from the site background so when i change it the design settings inside the text block or column using VComposor it remains the same
any ideas on this?
look im going for http://tinypic.com/r/x607xw/8
but what im getting http://tinypic.com/r/x607xw/8
changes made but nothing happens
thanks heaps
Please send me a link to your site so I can check this, also please try to add a class to your text block like this: http://screencast.com/t/JbtiwRvGLf9 Then use that class to set the background color as you like: http://screencast.com/t/LSm3oaErskM
You can use and add the same class as I did, just add the class like shown in the first screenshot and then add the custom css from below in your custom css field from theme panel:
.my-text-block-class {
background-color: #4db2ec;
works awesome thanks very much 🙂
just wondering do you guys do paid coaching calls for design ideas using your theme?
The answer would be no. Unfortunately we cannot offer any type of custom work as we work hard on the development, updates, fixes and support.
We can send you some site ideas using the theme though, please send us an e-mail to contact@tagdiv.com and we will send you a list if you like. Specify in your message about this discussion or send a link to this topic.
