problem with thai font
Dear: Support
i want to use thai font like kanit , prompt , mith , in web page and postcontent.
i find it in “Themepanel>Theme Font and open thai support in google font setting but i can’t find it
i want to know how to use thai font in this theme without use custom font.
I hope to hear from you soon
thanks.
Eff
Most of the elements fonts can be customized in the theme panel, font settings. If the fonts you need are not present in the font drop-down list, you can upload the additional fonts that you require
– https://forum.tagdiv.com/font-customization/
Like these fonts for example
– https://www.fontsquirrel.com/fonts/list/language/thai
If you’re interested in some basic coding you can load Prompt by simply overwriting the references to other fonts as required. As the Google fonts API is already loaded all you need to do is update the font references. Sadly it’s rather manual but quite easy to do.
