Problem with the display category
Hello world, I would have to inform you that this message was translated from French to English using Google Translate.
Externaute
I have this display problem in categories from the instalation of the theme, I looked on your formum and at the documentation but I found nothing as a solution to my problem.
Thank you for helping me.
Help !up!
Sorry for delay we don’t work on weekends, you have replied to your topic and we take topics in order from oldest!
When you set a category megamenu you don’t have to add submenu items. For parent category(with subcategories) set as megamenu all subcategories will appear automatically. So you have to remove sub items from there.
For example this a parent category – http://screencast.com/t/dgi5FBeTfeB is just set like megamenu – http://screencast.com/t/ECkpulttU2ec and the subcategories are added automatically – http://screencast.com/t/KJl17A7XzurH
Hope this helps!
it works .. Thanks
