This is my site: https://blackmagazine.com.mx/3d-flip-book/octubre/
I’d like to get some space between the header and the PDF.
I hope i find a solution for this issue. Thanks!
Hello @digitalblack!
You can add an empty space element: https://prnt.sc/7z1kPUdrkkUO in Composer or a margin bottom to the header zone: https://prnt.sc/v9Dsz5wWFH6N
Hello! Thanks for the answer, the problem is, on this page I cannot open Composer as I don’t see the button as I normally do on my site: https://prnt.sc/9GkJsodgCQjd
If you use a default template, then you can not customize it with the TagDiv Composer.
You can add a padding-top: 100px; to that iframe.
