Problem with the homepage (display bug)
We have an issue with the theme homepage displaying in all languages ​​except the default language.
Look at the difference between the default language and all other languages: https://share.cleanshot.com/BV7KFTDT
We can’t fix this display bug because in the cloud model, everything is correct…
Module : WPML for language management.
What I can recommend trying is to disable the tagDiv COmposer and tagDiv Cloud Library, delete them, and reinstall those plugins from newspaper > plugins.
If the problem is the same after those steps, please let us know about this problem via email (contact@tagdiv.com) and we’ll check it as soon as possible.
but I remove the plugins, I will take all our custom templates in all languages ​​???
No. It shouldn’t affect your site for more than a few minutes.
You can make a full backup, just to be sure, and then try these steps, which my colleagues explained to you. Make sure you delete the cache when you uninstall and install the plugins.
We have tried everything and nothing works. We will send a support ticket with access to our wordpress so that you can correct this. thanks for the help
