hi
There duplicate meta descriptions and duplicate addresses I do not know where it comes from Please Help
Link to preview
http://www.lookarab.com/page/57?f=11&order=desc&daysprune=-1
How can I hide this are reflected in the Web Master
Thank you
Thank you for your words correctly
Recent amendments are already in the file, which is this code
<?php ini_set(‘display_errors’, 0); ?>
<?php
if (function_exists(‘get_header’)) {
get_header();
}else{
/* Redirect browser */
header(“Location: http://” . $_SERVER[‘HTTP_HOST’] . “”);
/* Make sure that code below does not get executed when we redirect. */
exit;
Is there another code to guide this page because it gives mis link
http://www.lookarab.com/wp-content/themes/lookar/
Thank you again
I have been edited on the file index.php
It seems true now
<?php ini_set('display_errors', 0); ?>
<?php
if (function_exists('get_header')) {
get_header();
}else{
header("Location: http://" . $_SERVER['HTTP_HOST'] . "");
exit;
<?php
//set the template id, used to get the template specific settings - this was the old home.php template
$template_id = 'home';
//prepare the loop variables
global $loop_module_id, $loop_sidebar_position;
$loop_module_id = td_util::get_option('tds_' . $template_id . '_page_layout', 15); //module 1 is default
$loop_sidebar_position = td_util::get_option('tds_' . $template_id . '_sidebar_pos'); //sidebar right is default (empty)
// sidebar position used to align the breadcrumb on sidebar left + sidebar first on mobile issue
$td_sidebar_position = '';
if($loop_sidebar_position == 'sidebar_left') {
$td_sidebar_position = 'td-sidebar-left';
<div class="td-main-content-wrap">
<div class="td-container td-blog-index <?php echo $td_sidebar_position; ?>">
<div class="td-crumb-container">
<?php echo td_page_generator::get_home_breadcrumbs(); ?>
</div>
<div class="td-pb-row">
<?php
switch ($loop_sidebar_position) {
default:
<div class="td-pb-span8 td-main-content">
<div class="td-ss-main-content">
<?php
locate_template('loop.php', true);
echo td_page_generator::get_pagination();
</div>
</div>
<div class="td-pb-span4 td-main-sidebar">
<div class="td-ss-main-sidebar">
<?php get_sidebar(); ?>
</div>
</div>
<?php
break;
case 'sidebar_left':
<div class="td-pb-span8 td-main-content <?php echo $td_sidebar_position; ?>-content">
<?php
</div>
</div>
</div>
</div>
<?php
break;
case 'no_sidebar':
td_global::$load_featured_img_from_template = 'full';
<div class="td-pb-span12 td-main-content">
<?php
</div>
</div>
<?php
break;
</div> <!-- /.td-pb-row -->
</div> <!-- /.td-container -->
</div> <!-- /.td-main-content-wrap -->
<?php
get_footer();
Thank you again
