Some places in my blog feed the title of the article is more than 2 line height.
When there is a 3 line height title the two article is not equal height.
How can i adjust this? Is there a method to leave 3 line height to the post titles in the feed in order to keep them equal height?
See the problem here: https://snag.gy/tV4mnq.jpg
Thanks for your kind help, in advance,
Sincerely,
It seems to be a mess in your homepage, sorry! If you will check the default theme, you should not see this error. Everything seems to be good aligned. If you have some additional customizations and if you are using some untested plugins, you should remove all of them, clear all the caches and check the results.
Hope this helps!
Hello mrgergoke,
You should provide your website URL so I can take a closer look at it and also, so I will be able to provide a more accurate response. Please make sure that you are using the latest theme version and also, if you are using some untested plugins, try to disable all of these and leave just only bundled plugins to be active to exclude any conflicts. Before providing your URL, if your problem is still there, you should try to make a new clean install and check the results because I have checked on my end and this problem does not happen.
Hello Catalin,
Here is the website url: https://rendeljkinait.hu/
The problem occurs, when there is a 3 line title and a 2line title article next to each other: https://prnt.sc/gv6l4j
We tried everything, but nothing helped:(
Thanks,
Here is talking about Excerpts which can be adjusted from Theme panel, like this -> https://forum.tagdiv.com/excerpts-introduction/
Hello mrgergoke,
Sorry for this but please notice that our theme does not have any such an option that allows you to establish the title length by a number of lines, sorry! The only way for this is using the title length by letters or words using our Excerpts section.
