Hello Team,
I have been facing issues with the posts which uses the visual composer when the tagdiv composer is active. Currently tagdiv composer is not supported for posts. I used Visual composer to built some of the posts. When the tagdiv composer is active the post page is distorted and the layout is not proper. Have the look at the images for reference.
When the tagdiv Composer is active
When the tagdiv composer is not active the post pages looks proper.
For now I deactivated the tagdiv composer. Once this problem is resolved, I will switch to Tagdiv composer.
Unfortunately using both page builders at the same time will cause layout issues. We only recommend using one or the other Never both at the same time. For pages, sorry but not even visual composer is recommended: https://forum.tagdiv.com/search/use+visual/
The page builders in our theme are destined for pages only.
Thank you for the reply. The layout problem is there even with only the tagdiv page builder active. Kindly fix it. I have deactivated the Visual composer then also the same layout issue in the posts where the visual composer was used. If the tagdiv builder is only for the pages please make it to work in posts, so that is supports some general elements.
