problem with the search function, not work
Hello, I have a problem with the search function, I Even Made The try disable all plug-ins, but the same does not work, does not open when I click the search, every Help And well accepted thanks
website http://www.lifestar.it
I’ve checked your site and found a js error in browse’r console: http://screencast.com/t/336nNWAZFp
Please make sure that you’re using V 3.1 of Newsmag theme, this version is available on themeforest, also try to deactivate all plugins except Visual Composer, deactivate the child theme, clear all caches, p[urge cdn files if your using then testy the site again.
Let us know how it goes.
