Problem with the second sidebar
I am using 2 sidebars for my site: 1 for pages and a 2nd one for posts. Whenever I go to “widgets” section in wordpress my blog sidebar’s widgets disappear and I have to add them all over. Same happens each time i renew the widgets page. Another thing is that I can not edit my additional sidebar’s widgets. They can’t be open! I can’t change the title, can’t select the ads.
Would really appreciate some help.
Thanks a lot,
Natalia
Hello Natalia,
You can try 2 things in order to fix this. The firs one is to check your system status and see if the options there are within the recommended parameters (they should be green): http://screencast.com/t/ZuwtasWUh
If your values need to be increased you can follow this topic to adjust them: https://forum.tagdiv.com/topic/image-error-and-status/https://forum.tagdiv.com/system-status-parameters-guide/
Another thing you can try is to check your sidebar titles. If you have any “special letters” there it will cause these errors. The widget area only accepts the basic characters. No symbols or language specific letters. Try to change your titles to just plain text and check if the issue is still there.
Let us know.
