Problem with theme footer and infinity scroll
Problem with footer, infinity scroll
I have a problem with my theme footer in my site. It doesn’t apear right in my site (like it runs in the backround and when i try to edit the footer with td composer it doesn’t let like the footer doesn’t exists). When i imported a footer from cloud templates it seems like the theme footer runs also at the same time in the backround an there are a lot of conflicts and my site breaks down in many places and it slows down also…
Also in the infinity scroll of my single post from the second article and scrolling down there is a lot of blank gap from article to article, and the comments does’t appear at all (only in the first article they apear and from the second and scrolling down the don’t apear and there is a big blank gap in there place).
Also when you scroll down from the second article and down the sidebar stops to sticky, and it doesnt follow the flow of scrolling down.
A would much apreciate for your help
Hi theodim74,
If you are using a pro demo, the footer is a cloud template, then you’ll need to edit it from a page, for example, you can edit the homepage, click on edit with tagDiv Composer -> https://i.imgur.com/uweNRrc.jpg after that go down to the footer end edit it how you want (now you can customize the the whole web-page from fronted).
For the problem with infinite loading, please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also for the moment the sticky sidebar can be use only for first article in infinite loading.
If there are still some problems, please provide some more details with some screenshots and a link where I can check these problems.
Let me know the results!
Thank you for your answer.
I already tried several times editing from TD Composer from my home page and it doesn’t let me like it is a “ghost” footer runing on the backround.
I use influencer tamplate and when i imported a cloud footer from the tamplates it lets me edit it from the home page (and not from the cloud templates page) but it seems like there is a second footer runing on the backround… You do not see the second footer in live site, but you see two same footers, like douplicates, in the editing mode of TD Composer from homepage…!!! As a result of this, a lot of conflicts are taking place in my site, it slows down, when you scroll down in some parts of scrolling the megamenu apears without the mouse being at the menu, and also it cuts the lower parts of my articles in the infinite loading from the second article and down…
Also when i import a footer from the cloud templates, the section from the Theme Panel that controls the footer section (instagram etc. etc.) doesn’t have any choises any more… they just desapear or diactivate… I can’t control the footer section from the Theme Panel any more…
My site is vmotion.gr
Please help me with my problem.
Please tell me whatever you need from me to provide you (Pictures, My wordpress admin panel, my host panel…)
Thank you very much in advance!!!
Your footer is this one -> https://i.imgur.com/cuu4NdQ.jpg this is set from theme panel, until you’ll set other templates, this will be your footer template.
Also as I said above the cloud templates can be edited only when are set on pages or cloud templates, these do not had a edit button with TD Composer in cloud templates -> https://i.imgur.com/ymo4pb6.png therfore you need to assign it, you can do it from here -> https://i.imgur.com/VVdGlgY.png or editing the homepage -> https://i.imgur.com/LHabwkZ.png -> https://i.imgur.com/QAo5KXw.png
How to Customize your Footer with Newspaper Theme -> https://tagdiv.com/how-to-create-a-footer-with-newspaper-theme/
If there is still a problem, let me know, also please provide some screenshots.
