Problem with Theme panel setting
Hi there,
When i want to change any of the options from “Theme panel” i got only loading animation and nothing more. Setting are not changing.
Hello sallyboom,
Firstly, you should check your system status parameters to be increased according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Make sure that your PHP memory is increased as expected if you want to achieve good results.
Hi there,
I changed the memory to 64
And still when i want to change setting in Theme panel i got only loading animation and nothing more.
settings
loading
Please contact us via email at contact@tagdiv.com and provide wp-admin and a link to this topic so we can login and investigate this issue.
