Problem with thumbnail size
I have problem with thumbnail size on my web http://www.rogner.cz. When I add new post, size of thumbnail on main page is smaller than other thumbnails – see https://imgur.com/a/6j9KYra
Thanks for help!
  • This topic was modified 5 years by Rogner.
Usually this problem is solved using our guide from here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Hope this will help you!
Thank you, but it doesn’t work. I regenerated this image and it is same. Size of image is same like image by post “Senohraby – Poddubí – Chocerady – Kloučky – Stříbrná Skalice” on http://www.rogner.cz… but thumbnail looks different…
Is possible to have same thumbnail size by all post even they have original different size?
Usually that should fix the problem, also I see that you have another problem https://i.imgur.com/tm1S9eT.png this problem can be solved using those guides:
– https://forum.tagdiv.com/topic/font-blocked-from-loading-by-cross-origin-resource-sharing-policy-no-access-co/
– https://stackoverflow.com/questions/25577981/font-from-origin-has-been-blocked-from-loading-by-cross-origin-resource-sharing
– https://webmasters.stackexchange.com/questions/71630/font-blocked-from-loading-by-cross-origin-resource-sharing-policy-no-access-co
Also for the problem with the thumbs size, please make a test only with theme plugins, clear all cache and try to regenerate them again.
Let me know the results!
