I install WP RSS Aggregator for rss feed. When a feed source imports item the thumbnails from all blocks disappeared. Also in the home page, the big grid 6 appear only one image.
Please, how shall I overtake these problems?
Thanks in advance.
This topic was modified 10 years by
MarStat.
When the thumbs dissapear from the blocks, this usually means you have a plugin incompatibility. Please remove all your plugins except visual composer and the aggregator and test it again . Also clear the cache and reset cdn if you use it. Unfortunately the rss agreggator plugin is not tested with our theme so it could be the one creating the problems in the first place. If the problem is still there after you remove all other plugin, then you need to find another rss plugin.
Thanks for your answer.
I have already disabled the WP RSS Aggregator and the thumbs seem to be appeared. The issue about big grid 6 did not fix in the home page(url: magdasnews.gr). Only one image is shown.
I try another type of big grid and even create a new home page but the problem remain.
Could you help me to solve it?
Thank you in advance!
Please provide a link so i can inspect as the one you provided simply sais coming soon: http://screencast.com/t/u8PdGPwySuS I need to access your website so i can see the big grid.
If you want us to take a look at the site you can provide wp-admin so we can inspect the back-end. Please send an email at conatct@tagdiv.com and provide your login information. Also include a link to this topic.
MarStat
What RSS plugin did you end up going with? I’m using WP RSS Aggregator too and am having a similar problem using the feed items in a grid with the Newspaper theme. I would to continue with WP RSS Aggregator as it lets me filter by keywords but am open to other plugins.
Thanks in advance
I updated WordPress to 5.1.1, your Newspaper theme to 9.6 and the plugin for automatically importing posts (wp-autoblog) to the latest version.
Since then the thumbnails do not appear in front page. There is featured image in every post which is shown in the post page and in the category page as thumbnail.
I disabled all plugins but the problem remained.
Please, i need some help to solve the problem.
Thank you in advance.
You can send us the details and admin at contact@tagdiv.com, we will try to identify why the thumbnails are not appearing in the homepage.
