Hello, I have a problem with thumbnails, i regenerate them with 2 different plugins but nothing happens, i dont see thumbnails. can you help ?
http://lepetit.buzz/10-illustrations-vous-parleront-si-vous-etes-accro-a-la-nourriture
Look for all related posts, no thumbnails. I deleted cache from super cache and from navigator chrome, same issue.
Thank you for your help
The main problem with thumbs not showing is this one you have in the console: http://screencast.com/t/6WFhil3rd
JS errors break the lazyload animation. Please disable all plugins except visual composer, clear cache and reset cdn. Plugin conflicts are the number one reason for js errors. These can also be caused by custom modification not done properly.
Let us know how it goes.
