Problem with title of post
Hi I have a problem. Post type 11 title is black and is not visible. The rest is all right.
Screenshot
If you change the default post title color, then on the black templates it will not switch to white automatically anymore. The post title color is dynamic by default if not changed. Either remove the post title color from the theme colors section: https://www.screencast.com/t/gcVLSJc3I4C
Or change the color to one that can show up on black as well,
Or use this custom css to manually change the post color to white on the video post template in particular:
.single_template_11 .td-post-title .entry-title, {
color:white;
