Hi, I have a problem with Theme panel. None of the changes I`ve made were saved. This is my third site based on your theme and the first time I have a problem with it. I made a translation and clicked “Save settings” but although changed seemed to be done afer returning back to Theme Panel there was no translation at all.
I have the same problem with changing theme color and Block Settings (thumbnails)
Jerzy
First try to disable all plugins and see if the issue is still there.
If this doesn’t work then the issue may be caused by the max_input_vars value on your server, default is 1000 and you may have reached the limit. If the host allows it (check the host documentation) you can change it via php.ini to 5000 , save and restart Apache (it’s also stated in the documentation).
If the host doesn’t allow this you have to ask the host administrator to change this value for you.
Thank you, Emil G.
