Problem with Upgrading WordPress to 5.5
hello tagdiv team.
did this template (newspaper) working properly on the latest version?
I have an issue due to upgrading wordpress to the latest version.
See the image the problem
I can’t expand all the panel, maybe there is plugin conflict with the theme?
How i fix this issue.
Thanks 🙂
Yes, the last version of Newspaper v10.3.6.1 is working correctly, this is compatible with WordPress v5.5, but before you make the update, please make a full backup to your website and database and only after that make the theme update -> https://tagdiv.com/update-newspaper-theme/
If the problem persists, please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
