Hi TagDiv Support,
i have a Problem regarding the WordPress User Profile.
For example:
The Link to the Userpage ( nearby the Login Button) brings me to a userpage wich is not correct.
https://bitjunkie.org/forums/users/bitjunkie78/
i want to change this link to:
https://bitjunkie.org/users/bitjunkie78/
How can i change this Page Template and the Linksettings?
Best Regards,
Marcel
Hi Bettina,
thaks for your Reply.
Here are some mor Information with more Details:
1. Here is the Landingpage from my Webside. Mouseover my Name( i am logged in) showes the following Link ( left corner in the picture)
2.Behind this Link you the the page like this in the Picture. Seems like css is brocken….?
3.The Middle Area of the Same Page
4. Bottom /Footer of the Same Page:
5. I want to see this page with correct css etc.
the only diffrent is user / users in the Link.
I dont Know in which Part of the Newspaper Template i can change the Linksettings.
You need to change the name of the user in the database in both places: https://prnt.sc/11bx7sp
Give it a try and then the link should be automatically updated.
Hope that helps you!
