Problem with using Swiftype
I installed Swiftype for new search results, and it works fine except on the search from the top menu – it gives me 2 drop down search suggestion boxes. I need to get rid of the default one. Can you please let me know how to disable it.
you can take a look at http://blog.kozzi.com/
  • This topic was modified 11 years by Kozzi.
Hello Kozzi,
I checked your site and it only shows one search box. It seems to work fine now.
http://screencast.com/t/R4NKw1w7B
Please provide more details if this is not what you mean.
I am not referring to the search box — start typing in a search in the same box you show me in the screenshot — type in the word ‘make’ for example — and you will get 2 search suggestion drop-down boxes. http://blog.kozzi.com/wp-content/uploads/2015/09/Screen-Shot-2015-09-15-at-8.52.08-AM.png as shown here.
Dan
  • This reply was modified 11 years by Kozzi.
Hello Dan,
I checked your website and saw the overlapping results boxes. You can hide the default one (if this is what you want) using a custom CSS:
.td-aj-search-results, .result-msg{
display:none;
Just add it to the theme panel:http://screencast.com/t/WU20kh50
If you want it restored in the future, just delete the code and it will be displayed again.
Works great — thank you very much 🙂
