Problem with video ad balloon
hi! i have a problem with an ad placement – a video ad balloon. It doesn’t open completely.
I also run this ad in my other wordpress site using Sahifa theme and it opens without problems.
please HELP.
only opens halfway, the view is muddled –>
should be like this –>
  • This topic was modified 11 years by hoops.
Please also provide your site’s URL so we can inspect it and let us know how have you implemented it.
hi! you can check it at my site here –> http://hoops.ph
although it doesn’t open everytime. it only has error when the ads have videos.
this is the ad code located in the <body>
<!-- Zone Tag : Hoops Pilipinas Universal Tag -->
<script type="text/javascript">
innity_pub = "211a7a84d3d5ce4d80347da11e0c85ed";
innity_zone = "48268";
</script>
<script type="text/javascript" src="https://ssl-cdn.media.innity.net/lib/network.js"></script>
thanks!
This is how I see it: http://screencast.com/t/k4x6LVuaXPdm and seems to look fine. I couldn’t get one with videos to show up so I can inspect it but I suggest you also test this with all your other plugins disabled, empty all caches and also check browser’s console for errors when this happens as I suspect this could be caused by a js/css conflict.
thats a totally different ad.
im also sure as its not an issue with the plugin as when i use Sahifa the ads display completely.
  • This reply was modified 10 years by hoops.
check out my other site that uses Sahifa –> http://brgyginebra.ph
it has the same set of plugins, so its really an issue with the theme.
Please let me know where to look for it or how to make it appear on your site to inspect it because I have checked both sites and couldn’t find the “video ad balloon” you refer too.
