problem with video advertising code
I’m trying to insert a tag for video advertising on the right place but it always changes the layout of the website.
According to the company who takes care about the advertising on my website, I should insert the tag inside the <body> and the result should be a video advertising on the bottom right corner of the website (on desktop) and a video advertising on the bottom of the smartphone screen (on mobile).
After I insert the ad tag right before closing the <body>, this is what happens:
Desktop: sometimes it shows the video advertising, but most of times shows a banner after the footer who changes the website layout.
Mobile: video advertising never appears.
My question is: where should I insert the ad tag so everything works according to expected, both in desktop and mobile?
The website is: http://www.vortexmag.net
Thank You for your help!
Hello master2501,
Notice that all of the settings about the AdSpot can be found in our documentation from here -> https://forum.tagdiv.com/newsmag-header-ads/ Our theme has been designed to be used only with Google AdSense code. If you are using another source of the ad code, notice that we cannot say for sure if it will work or not, sorry!
If is not what you mean, provide more details about your problem so I will be able to provide a more accurate response. Provide some useful screenshots of the problem so I can identify it closer.
