Problem with videos on mobile
I have a problem with the videos on my test website.
I am not using YouTube but videos hosted on my server. On desktop – everything seems to be fine. On mobile – there is a problem with displaying the video at first (when you click on the video it loads up perfectly).
Is it possible to help me on this issue because I am making a relatively large installation with over 150k posts and around 10k of them have videos inside.
http://wp.ecomservice.bg/?p=682 <– this is a sample URL where you can see the issue.
Best regards!
I think that this post is a draft because I can not access it https://i.imgur.com/gIuWJ4R.png
Please provide a video with your issue.
Please provide a video of how it looks for you the video on mobile to be able to understand and help you.
I uploaded around 50k posts (99.9% of them don’t have videos) via WP All Import.
For the ones that have a video I add this code before the content in order to show the video:
<div class="wpb_video_wrapper">
                    <video controls="">
                        <source src="https://eurocom.bg/show_videos/news/',max(video_directory),'/',max(video),'">
                        Your browser does not support the video tag.
                    </video>
                </div></div>
Basically I add my video url to the post. This is not an ideal way to import them I believe but that is the best idea I came up with. On desktop it works good – once you enter the post it shows a thumbnail of the video. On mobile however it just shows the play button. If I click the play button it works well and once I see the video – the thumbnail remains there.
it seems to look good on the homepage it shows that there is a video inside and it has grabbed the thumbnail I imported
when I enter the post it has no thumbnail, when I click play - the video is working
https://ibb.co/MMVznxS
https://ibb.co/3cr9ZZH
Can you advise me on how to properly import posts with videos hosted on my server?
  • This reply was modified 2 years by petar777.
Can you please provide the link to your website?
Note – it is HTTP currently
The website is not working -> https://i.imgur.com/ZWme3Cj.png
Can you give me your IP to see why you can’t see it? I’ll ask my host.
This is my ip address 192.168.0.32
Your external one if possible.
5.2.168.55
Are you sure you are trying to access it with HTTP, not HTTPS? Try this link http://wp.ecomservice.bg
Do you have blocked access for a country? I have tried it on different browsers, and it still is not working.
Thats weird… Can you check if you can access eurocom.bg and zdravital.bg (these our current websites without the theme)
Those websites are working. Are you sure that is not something like localhost?
I installed SSL can you check finally? With https? If it works see the issues we mentioned before.
The site works, but I didn’t find a post with a video.
Check it again now, I uploaded 100 videos (latest posts)
Can you please provide a video of how you do the posts? You add self-hosted videos in the post content, but for them to work, you need to set the featured video here, and it must be of the video type https://i.imgur.com/qe6xLAV.png -> https://forum.tagdiv.com/featured-image-or-video-7/. For those, you need to add a featured image because it is not generated automatically.
https://www.loom.com/share/28bc696e620e408ca5ef380a8ffb3d84
I recorded this one, I hope you can get an understanding of what I am doing.
PS: The problem is that I upload videos from my server, they are not hosted in YouTube, Vimeo or whatsoever. Is it possible for your support to help me on this and find a way to make it work?
I see that on desktop it fetches the video thumbnail whereas on mobile it has no thumbnail.
If you have self-hosted videos, then a thumbnail or featured image won’t be generated automatically for those posts; instead, you’ll need to upload one for each post.
I believe you didn’t watch the video and don’t understand my question. Anyways, I will try to explain it again.
I upload the video and upload a thumbnail, so the thumbnail is not an issue, all my thumbnails are working perfectly.
If you open this link https://wp.ecomservice.bg/vox-populi/test/ from a mobile device (NOT inspection tool and simulate a mobile device) you will see the play button in the page without any video behind it, once you click it it will appear and stay there.
https://ibb.co/phnG6Gk here is an uploaded image so that you can understand what I mean.
It works well on desktop – it fetches the video but on mobile it doesn’t.
So thats the only issue I have currently.
Viewing 25 posts - 1 through 25 (of 26 total)
