Problem with Visual Composer
Config:
Newspaper 7.1.1, Visual Composer 4.8.1
For some reason there is very little functionality in the VC; the front end editor is non existent and the element selection doesn’t close. I have deactivated all plugins, removed the VC and reinstalled it with no change in functionality. Below I have copied the output of the FireFox console which may give a clue although it is meaningless to me.
JQMIGRATE: Migrate is installed, version 1.4.0 load-scripts.php:9:542
window.controllers is deprecated. Do not use it for UA detection. ace.js:1:23901
TypeError: $template.get is not a function
composer-view.js:165:12
This site appears to use a scroll-linked positioning effect. This may not work well with asynchronous panning; see https://developers.mozilla.org/docs/Mozilla/Performance/ScrollLinkedEffects for further details and to join the discussion on related tools and features! post.php
Any help would be appreciated.
Regards, Bob
Hello Bob,
The front-end editor from visual composer was removed as it created issues with our theme. I’m not sure how the “element selection doesn’t close” but issues with CV were caused by the latest version of wordpress and VC 4.9
Please update visual composer to version 4.11.2.
You can follow this guide: https://forum.tagdiv.com/how-to-use-visual-composer/
Hi Bogdan:
Thank you. Installing VC 4.11.2 seems have solved the problem. I had forgotten that in updating Newspaper I also had to reach into the file and independently update the VC plugin.
Regards,
Bob
