Problem with Visual Composer
Hi there,
I’m having a problem with Visual Composer.
I’m using Macbook Pro with MacOS Sierra 10.12.5.
Suddenly Visual Composer doesn’t show anymore. When I have to edit a page and click on VC the page appears to be empty. The other members of the team do not have the same issue, only me.
I tried to access with Safari, Firefox and Chrome but all give me the same issue.
As I said, that has happened overnight since I never had any problem before.
Do you have any idea what is that cause the problem?
  • This topic was modified 9 years by bariton.
Hello bariton,
Please notice that at the latest theme version we have released our page builder which is named TD Composer and also, wich come ready installed with the theme. Also, please notice that if you will install the Visual Composer, besides this plugin, notice that might appears some conflicts. For a correct use of our page builders, please check the following useful guide here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/ -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
