For some reason when I tried to move a block in one of the section up higher than it was after saving it the whole layout got messed up and for some reason even tho 1/1 is selected on the layout of that element the widgets/blocks don’t stretch out the way they’re supposed to.
Then when i click on the layout option tab 1/1 is select but so is 2/3 + 1/3 and the 1/3 + 1/3 + 1/3 option and I can’t deselect any of them for some reason. Anybody know how to fix this?
LGNDVRY.com
It’s kind of a funky product, frankly.
I ended up trying about three different things until I got the hang of its quirks…. so, I found it easer to start with blank slate vs using templates, then try things, then start over if I don’t like that or run into one of those oddities.
I also found using Chrome worked better than IE11, if using Windows.
I believe you refer to the Visual Composer issues which appears with older versions of VC when updating WordPress to 4.1
I have noticed while checking your site that you use the latest theme version (1.4) and the 4.3.4 version of VC which can cause this.
This issue appears because of the Visual Composer plugin when updating to WordPress 4.1. We have included the fixed version of the plugin(4.3.5) within the latest theme version so please make sure you update the Visual Composer plugin from the /plugins folder using this guide: https://forum.tagdiv.com/how-to-update-visual-composer-plugin-wpbakery/
Please let me know how it goes!
