Problem with Visual composer
Hello
I’m receiving the following error when trying to add an additional widget bar:
http://screencast.com/t/shRZ4KLJ
i disable all pluggin to see if the problem is any of those, but the error remains so i guess is a problem of the theme.
And i’m this problem with the child theme:
http://screencast.com/t/oyaF3Uwbx
and at installing this is how the theme looks:
http://screencast.com/t/OAVKlDetrSV
  • This topic was modified 11 years by raugustox.
That error is from Visual Composer, we also open a ticket at the plugin support regarding this and we hope it will be fixed in the next update.
Please make sure that you use the latest version of the theme 6.2 and make sure that you update also the child theme to this version, you can find it in the /code folder, as this issue was fixed and the Big Gris should not appear like this anymore.
I run in too issues as well with VC it don’t format some of the grids on homepage correctly..
Like the Big Grid 1 for me to use that i have to turn off VC and use the tagDiv Visual Composer Shim plugin for the grid to work correctly….i reather use the “tagDiv Visual Composer Shim” then the VC that slow your site down and have a lot of things you don’t even use…
  • This reply was modified 11 years by Steven.
