Problem with Visual Composer
I have a problem with visual composer. It doesn’t work at all.
Can you help me?
Pietro Maggi
http://www.osservatoreseriale.it
Hello pietro89,
The latest version of WordPress ‘break’ the Visual Composer. Please try to update the theme to the latest version (v.7.0) and also, the Visual Composer to the latest version (4.11.2), clears all your caches and check the results and see how it works.
Thank, now it’s working but there’s a new problem with the social counter Plugin, Facebook counter doesn’t work, and i have already updated theme, vc and the plugin indeed.
Hello pietro89,
Please ensure that you are using the latest version of Social Counter (4.0) for the latest version of the Theme (7.0), clear all your caches and check again the results. Please notice that the Facebook counter is not live and it may take a while until you get the correct results for your counter.
Hi Catalin,
everything is updated to the latest version and caches are cleared to.
The counter shows 0 like instead of 1600, i think it’s doesn’t recognize the Facebook page at all (https://www.facebook.com/osservatoreseriale/).
Hello pietro89,
If you have ensured that you have followed all my steps and you have the latest version of these plugins, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect your setup page. Also, please provide the link of this topic so we can identify you.
