Hi there,
I have a problem with page font family and font size.
I tried to change page font family and font size in theme fonts but nothing happened to my page.
However, after I changed from Backend Editor (using Cisual Composer) to Class mode and delete the codes before and after the paragraph, it worked.
Can you please me address this issue?
Thank you very much.
The font section of our theme as you probably seen is very comprehensive. You can change most fonts from the it. On your page, it depends what you want to change. modules ad blocks can be affected by their setting not the page setting: http://screencast.com/t/X6WqtmqJnt
Please provide an example of what did not get changed and where you changed it from so we know what to look into.
Hi Bogdan,
Thanks for your reply.
To elaborate on the issue, please see my configuration in
http://www.screencast.com/t/oV3859p2 (Basically, I changed the font families and font sizes in pages)
Then I created a content with Visual Composer (http://www.screencast.com/t/l3n1tf6f). After entering preview mode, the content wasn’t changed as configured (http://www.screencast.com/t/0RmJoyp0F)
Then I just played with it and found that when I changed from Backend Editor (Visual Composer) to Class mode and delete [vc_row][vc_column][vc_column_text], Font families and font sizes worked. (Please see http://www.screencast.com/t/xrhzWPtkmWn0 and http://www.screencast.com/t/UJLQJbVF)
However, when I used Visual Composer to add other contents, it just went back to the previous stage (No change for font families and font sizes).
I also tried to deactivate all plugin but it didn’t work.
Hello Sitthinunt.p,
All fonts and sizes settings from Theme panel->Theme fonts does not affect the content element of Visual Composer. If you will remove Visual Composer tags from Backend editor then all settings of fonts and sizes will apply.
For more information about fonts, please check our documentation here: https://forum.tagdiv.com/font-customization/
Hope this helps!
Thank you for the message!
