Problem with Visual Composer
I bought this theme to replace the one I already use for my site.
I used the Visual Composer plugin which I bought the liscence.
The problem is that your theme sets restrictions for this plugin so that I now I can only use half of the functions that I could use.
Is there a way to remove these restrictions so that I can have access to all the functions for which I paid liscence?
PS. I can send you the number license for verification.
I wish to congratulate you on the work for this theme.
(Translated with Google)
Helly,
try this: http://screencast.com/t/u1RRVIR8u
we removed them because we did not styled them correctly and we did not consider them a priority.
Everything works fine. Thank you very much.
