I’m trying to create a Homepage with Visual Editor, but I’m having problems with it..
I build all the page and then I click Publish to see how it looks, but when the editor page loads again, all the “rows” are blank. And when I switch to classic view, there’s nothing but some empty strings, like: [vc_row][/vc_row], and when I load my Home on the front end, it’s all blank, without the snipets… Can you help me, please?
And I also just found out that I can’t change my “Theme Color”… it’s always blue now… :/
http://screencast.com/t/ykswSYeRu
http://screencast.com/t/QCpJsh0rmbs
http://screencast.com/t/HLQThitjPX
Please, I really need to setup that soon…
Maybe I could provide a login access for you to check out?!
I think I found the reason for your problems.
I see you have many updates you still have to make
And it looks you like you have some editor plugin that is not working.
Also your editor looks different than mine, where does this blue green red wave come from?
Theme updates, you mean?
This wave is the Icon of the Visual Composer..
I just bought the theme and installed the patch that comes with it. (v1.7.1)
Seems like the ajax doesn’t work properly and WP is not recording my changes… 🙁
I’ve disabled all my plugins and things seems to be working now… although I’ll still doing some tests.
But thanks for your help… maybe you should have all the money that “TagDiv” got for support… 😉
For 45 dollars I believe it is not only the developers task to help but the users should help each other also if they can.
But yes the developers should be there and be the foundations of the support.
I am still hoping they will help me with my problem its been 4 days
https://forum.tagdiv.com/topic/featured-video-and-dailymotion/
PS: I believe your theme is only blue because you have the caching on, if you want the caching on you have to edit in the css file, they have answered this in one of the forum threads. They said they will fix it
https://forum.tagdiv.com/topic/theme-speed/#post-1265
https://forum.tagdiv.com/topic/theme-speed/#post-1348
Disabling the plugins made my theme color work again. I must figure out what plugin is making this mess…
I saw your thread, its kind of complicated (to me), but I think the developers have the duty to help the customers, just as they advertise everywhere with those non-sense graphics. Once they don’t, and use customers time to do all the work, maybe they should split their comission with customers… What about a half priced value, hah?! That’s my suggestion.
Anyway, thanks for your kindness and helping me with these matters.
Hope we can help each other.
Really?
But it’s their fault not offering help about our questions refering to their products, as described on their awesome advertisings.. And it’s that what we’re discussing here, if you couldn’t get the point yet.
@sweetgunner we reply to you via email for wordpress access
I cannot believe it!
This question was not theme related, therefore as the community should I took part in helping this user with his theme unrelated question. We found the cause of his problem it was one of his plugins.
So that the theme developers could be able to answer theme related threads. But for some reason they prefer to waste their time with resolved non theme related issues instead of helping with theme related issues.
But this is the help I got
https://forum.tagdiv.com/topic/featured-video-and-dailymotion/#post-1914
I am baffled
@dalandau already helped me solving these issues. I’m still testing the theme for my purposes.
@Marius Actually I found out that “tagDiv speed booster”, when activated, makes my Theme Color go blue… How can I fix that? Is there any CSS related to the theme color?
yes I told you this before
https://forum.tagdiv.com/topic/problem-with-visual-editor/#post-1885
But as you say, tagdiv support theme have decided to ignore this subject you asked about in this thread or to elaborate on the answer I gave you
oh yes, i’m sorry… i’ll check that link. thanks once more @dalandau 🙂
