Good morning:
To validate w3c I get the following errors:
Error: Element style not allowed as child of element div In This context. (Suppressing further errors From this subtree.)
From line 430, column 1; to line 430, column 14
↩ </ div> ↩ <style scoped> .td_ui
Contexts in Which style element May be used:
If the scoped attribute is absent: where metadata content is expected.
If the scoped attribute is absent: in a noscript element That is a child of a head element.
If the scoped attribute is present: where flow is expected content, but before any other flow content other than inter-element whitespace and style elements, and not as the child of an element Whose content model is transparent.
Content model for div element:
Flow content.
How you could fix it?
Also note, the ‘old/classic’ W3C checker had a lot of issues with HTML5 and nextgen HTML parsing; we went through this on a Bootstrap only project.
You might try the ‘nu’ version they are working on, which is ‘experimental’ for testing modern next-gen HTML5+ era code:
https://validator.w3.org/nu/
Chris
HI
@gregy1403 we still use inline css for our blocks. However this is on our todo list and we hope that we will find an alternative in shortest time possible.
