Problem with widget mini card
I have a problem with the mini cart widget when I activate the tagDiv Shop plugin. If the tagDiv Shop plugin is inactive, the mini cart widget will correctly display the contents of the cart. When I activate the tagDiv Shop plugin, the mini cart widget is empty even though there are products added to the cart. What could be the reason?
Hello @MaciejWolak!
Can you please provide more information about the issue you’re talking about?
