I am not able to re-order the widgets placed in my theme sidebars. Is anyone else experiencing this? Is there a fix for this or is this something I have to live with? Thank you.
Note you can’t easily edit any of the ‘pre-defined” sidebar areas in the visual composer; you need to create new row, e.g.,
[ x x ] [ x ]
then assign home page side bar to either std widget or custom widget for home page, which you create from one of the edit category page; then add desired items to the sidebar.
If you are talking about regular sidebars under appearance > widgets
then likely a plugin conflict?
@rolotomazi Please provide more details if you still have this issue and also provide your site url
Thank you for the responses. I believe Chris had it right when he wrote that it’s likely a plugin conflict but actually in this case, it was a conflict with a previously installed theme. I tried to delete it but there are certain features that still carried over and were causing issues. I’ve re-installed the theme on a clean WP install and everything seems to work. Thank you so much for looking into this with me! 🙂
