Problem with WP Pagebuilder
Previously I was using another WP theme, and my custom page made by WP Pagebuilder was working fine. Now, after activating Newspaper 9, my page is not showing in mobile devices, and in PC, te page appears with issues.
I tried to install new pre builded page, but it appears with the same issue, so I think that it is a compatibility problem with Newspaper theme. My page is http://motoristes.cat/club/
Up
I have checked your website and I saw that you are not using our theme, sorry! If you have created your homepage with WPBackery might be possible to appear some errors, sorry! Note that we recommend using our TD Composer functionality and also, the page should have to be created with that plugin. In the past, if you were used another theme and now, if you want to migrate it to our theme, could appear some issues and that’s why you will have to recreate your pages.
I am using newspaper 9. However, it is true that I create the page that is not working when I was using another theme.
The problem is that when I try to create a new page, it is also with issues.
I tried reinstalling the wp pagebuilder but the problem persists
Now i tested all my other themes and the page is working perfectly with all of them. The issue only appears when I use Newspaper 9
I repaired the page manually. However, the page motoristes.cat/club is not displaying in mobile devices. Why? Thanks
When the mobile theme plugin is enabled, you will have to create 2 versions for each page. One for desktop with the composer or in any way possible, and one for mobile with the simple mobile editor (can’t be built with the composer)
– https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
So you will have to edit the pages and enter content in the mobile editor, it should be at the bottom of the edit page screen – http://prntscr.com/o0abx0
In the mobile editor you can enter text, images, shortcodes should work as well.
If the mobile theme is not active, the same content from desktop will be displayed on mobile.
Thank you so much for your support, this information was what I need.
Have a nice day,
Regards
