Hi staff,
I have a problem with wp_ajax_nopriv_td_ajax_search on this website:
https://farmaci.torrinomedica.it
as you can see in this screenshot
https://ibb.co/fFkSMMj
newrelic measure a problem with admin-ajax
The problem of admin-ajax is caused by wp_ajax_nopriv_td_ajax_search as you can see here:
every call to this function wp_ajax_nopriv_td_ajax_search needs up to 3 seconds (!!) …
Please, can you help me to understand what is the problem and how can I solve it?
Please consider that this wordpress website has about 15.000 articles and is on GCP google cloud platform (varnish, memcached, redis … all works properly..)
thanks
alessandro gennari from italy
Unfortunately, please notice that we do not have any bad reports, regarding on Ajax Search functionality until now. Check the themețs requirements from here -> https://forum.tagdiv.com/newsmag-requirements-for-newsmag/ and ensure that all of these values have been respected. Try to make a new clean install to another sub-domain for testing, clear all the caches, purge CDN files and check if the results.
ok.
The problems are about 4 (four) slow queries to database.
Here you can see the queries:
https://ibb.co/CJRvtND
These queries need 50-60 sec to be executed…
Please can you tell me wich is the page that generates these queries?
so i can disable it..
is it the home page?
thank for your help
a.
Please notice that we do not have made our custom search and queries. We use exclusively WP_Query which is part of WordPress and also, we do not use any custom database query, sorry! Please check the following screenshots to see where these queries are used -> https://www.screencast.com/t/1MTd2e2p -> https://www.screencast.com/t/VUvmgP289Q -> https://www.screencast.com/t/V1ngmXov0R Also, another hint might be to try repairing your database from phpMyAdmin from here -> https://www.a2hosting.com/kb/cpanel/cpanel-database-features/optimizing-and-repairing-mysql-databases-with-phpmyadmin Before doing this, please make a full backup to your database to avoid losing all of your data.
