I have started getting the following error on the TDComposer window.
Following are the only new plugins installed since then I have started getting this issue –
Yoast SEO
WP Super Cache
Please note I have already tried deleting cache etc. I don’t want to disable either Yoast or WP Super Cache because without them there is no point of website.
Here is the link to my site – https://www.automationdojos.com/
react-dom.min.js?ver=16.13.1:238 Uncaught Error: Minified React error #200; visit https://reactjs.org/docs/error-decoder.html?invariant=200 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
at I.render (react-dom.min.js?ver=16.13.1:238)
at classic-editor-1710.js:83
at Object.window.yoast.initEditorIntegration (classic-editor-1710.js:83)
at HTMLDocument.<anonymous> (post-edit-1710.js:5)
Hello Bettina,
Thanks for your response.
As advised I disabled the Classic Editor plugin and re-checked the error. The error is still there but only the classic editor part of error is gone. Now the error is showing only Yoast part as below :
post-edit-1710.js:5 Uncaught TypeError: Cannot read properties of undefined (reading ‘registerPlugin’)
at i.registerPlugin (post-edit-1710.js:5)
at new i (post-edit-1710.js:5)
at post-edit-1710.js:5
Here is the problematic script as per chrome inspector –
/* translators: %s expands to Yoast SEO. */
Object(D.__)(“An error occurred loading the %s primary taxonomy picker.”,”wordpress-seo”),”Yoast SEO”)),r&&Object(E.createElement)(A.ClipboardButton,{isLarge:!0,text:r},Object(D.__)(“Copy error”,”wordpress-seo”)))}return this.taxonomyHasPrimaryTermSupport()?Object(E.createElement)(E.Fragment,null,Object(E.createElement)(n,this.props),Object(E.createElement)(G,{taxonomy:H[t]})):Object(E.createElement)(n,this.props)}}]),i}(E.Component);X.propTypes={OriginalComponent:P.a.func.isRequired,slug:P.a.string.isRequired};var J=X,ee=n(82);function te(e){var t,n,r=wpseoPrimaryCategoryL10n.taxonomies;function i(t){return e(“#yoast-wpseo-primary-“+t).val()}function o(t,n){e(“#yoast-wpseo-primary-“+t).val(n).trigger(“change”);var r=Object(S.dispatch)(“yoast-seo/editor”);if(r){var i=parseInt(n,10);r.setPrimaryTaxonomyId(t,i),”category”===t&&r.updateReplacementVariable(“primary_category”,function(t){var n=e(“#category-all”).find(“#category-“.concat(t,” > label”));if(0===n.length)return””;var r=n.clone();return r.children().remove(),e.trim(r.text())}(i))}}function a(o){var a,s,c;a=e(“#”+o+’checklist input[type=”checkbox”]:checked’);var u=e(“#”+o+”checklist li”);u.removeClass(“wpseo-term-unchecked wpseo-primary-term wpseo-non-primary-term”),e(“.wpseo-primary-category-label”).remove(),u.addClass(“wpseo-term-unchecked”),a.length<=1||a.each((function(a,u){u=e(u),(s=u.closest(“li”)).removeClass(“wpseo-term-unchecked”),1!==e(u).closest(“li”).children(“.wpseo-make-primary-term”).length&&function(n,i){var o,a;o=e(i).closest(“label”),a=t({taxonomy:r[n],term:o.text()}),o.after(a)}(o,u),u.val()===i(o)?(s.addClass(“wpseo-primary-term”),(c=u.closest(“label”)).find(“.wpseo-primary-category-label”).remove(),c.append(n({taxonomy:r[o]}))):s.addClass(“wpseo-non-primary-term”)}))}function s(t){o(t,e(“#”+t+’checklist input[type=”checkbox”]:checked:first’).val()),a(t)}function c(e){“”===i(e)&&s(e)}e.fn.initYstSEOPrimaryCategory=function(){return this.each((function(t,n){var r,u=e(“#”+n.name+”div”);a(n.name),u.on(“click”,’input[type=”checkbox”]’,(r=n.name,function(){!1===e(this).prop(“checked”)&&e(this).val()===i(r)&&s(r),c(r),a(r)})),u.on(“wpListAddEnd”,”#”+n.name+”checklist”,function(e){return function(){c(e),a(e)}}(n.name)),u.on(“click”,”.wpseo-make-primary-term”,function(t){return function(n){var r;r=e(n.currentTarget).siblings(“label”).find(“input”),o(t,r.val()),a(t),r.focus()}}(n.name))}))},t=wp.template(“primary-term-ui”),n=wp.template(“primary-term-screen-reader”),e(_.values(r)).initYstSEOPrimaryCategory(),Object(ee.a)()&&Object(j.get)(window,”wp.hooks.addFilter”,j.noop)(“editor.PostTaxonomyType”,”yoast-seo”,(function(e){return function(t){b()(o,t);var n,r,i=(n=o,r=function(){if(“undefined”==typeof Reflect||!Reflect.construct)return!1;if(Reflect.construct.sham)return!1;if(“function”==typeof Proxy)return!0;try{return Boolean.prototype.valueOf.call(Reflect.construct(Boolean,[],(function(){}))),!0}catch(e){return!1}}(),function(){var e,t=v()(n);if(r){var i=v()(this).constructor;e=Reflect.construct(t,arguments,i)}else e=t.apply(this,arguments);return w()(this,e)});function o(){return f()(this,o),i.apply(this,arguments)}return h()(o,[{key:”render”,value:function(){return Object(E.createElement)(J,d()({OriginalComponent:e},this.props))}}]),o}(E.Component)}))}var ne=n(23),re=n(22),ie=n(121),oe=n(165),ae=n(34),se=n.n(ae),ce=new RegExp(“\\[[^<>&/\\[\\]\0- =]+?( [^\\]]+?)?\\]”,”g”),ue=new RegExp(“\\[/[^<>&/\\[\\]\0- =]+?\\]”,”g”),le=function(e){var t=e.registerPlugin,n=e.registerModification,r=e.pluginReady,i=e.pluginReloaded;this._registerModification=n,this._pluginReady=r,this._pluginReloaded=i,t(“YoastShortcodePlugin”,{status:”loading”}),this.bindElementEvents();var o=”(“+wpseoScriptData.analysis.plugins.shortcodes.wpseo_shortcode_tags.join(“|”)+”)”;this.keywordRegex=new RegExp(o,”g”),this.closingTagRegex=new RegExp(“\\[\\/”+o+”\\]”,”g”),this.nonCaptureRegex=new RegExp(“\\[“+o+”[^\\]]*?\\]”,”g”),this.parsedShortcodes=[],this.loadShortcodes(this.declareReady.bind(this))};le.prototype.declareReady=function(){this._pluginReady(“YoastShortcodePlugin”),this.registerModifications()},le.prototype.declareReloaded=function(){this._pluginReloaded(“YoastShortcodePlugin”)},le.prototype.registerModifications=function(){this._registerModification(“content”,this.replaceShortcodes.bind(this),”YoastShortcodePlugin”)},le.prototype.removeUnknownShortCodes=function(e){return(e=e.replace(ce,””)).replace(ue,””)},le.prototype.replaceShortcodes=function(e){var t=this.parsedShortcodes;if(“string”==typeof e&&t.length>0)for(var n=0;n<t.length;n++)e=e.replace(t[n].shortcode,t[n].output);return this.removeUnknownShortCodes(e)},le.prototype.loadShortcodes=function(e){var t=this.getUnparsedShortcodes(this.getShortcodes(this.getContentTinyMCE()));if(!(t.length>0))return e();this.parseShortcodes(t,e)},le.prototype.bindElementEvents=function(){var e=document.getElementById(“content”)||!1,t=_.debounce(this.loadShortcodes.bind(this,this.declareReloaded.bind(this)),500);e&&(e.addEventListener(“keyup”,t),e.addEventListener(“change”,t)),”undefined”!=typeof tinyMCE&&”function”==typeof tinyMCE.on&&tinyMCE.on(“addEditor”,(function(e){e.editor.on(“change”,t),e.editor.on(“keyup”,t)}))},le.prototype.getContentTinyMCE=function(){var e=document.getElementById(“content”)&&document.getElementById(“content”).value||””;return”undefined”!=typeof tinyMCE&&void 0!==tinyMCE.editors&&0!==tinyMCE.editors.length&&(e=tinyMCE.get(“content”)&&tinyMCE.get(“content”).getContent()||””),e},le.prototype.getUnparsedShortcodes=function(e){if(“object”!==se()(e))return console.error(“Failed to get unparsed shortcodes. Expected parameter to be an array, instead received “+se()(e)),!1;for(var t=[],n=0;n<e.length;n++){var r=e[n];-1===t.indexOf(r)&&this.isUnparsedShortcode(r)&&t.push(r)}return t},le.prototype.isUnparsedShortcode=function(e){for(var t=!1,n=0;n<this.parsedShortcodes.length;n++)this.parsedShortcodes[n].shortcode===e&&(t=!0);return!1===t},le.prototype.getShortcodes=function(e){if(“string”!=typeof e)return console.error(“Failed to get shortcodes. Expected parameter to be a string, instead received”+se()(e)),!1;for(var t=this.matchCapturingShortcodes(e),n=0;n<t.length;n++)e=e.replace(t[n],””);var r=this.matchNonCapturingShortcodes(e);return t.concat(r)},le.prototype.matchCapturingShortcodes=function(e){for(var t=[],n=(e.match(this.closingTagRegex)||[]).join(” “).match(this.keywordRegex)||[],r=0;r<n.length;r++){var i=n[r],o=”\\[“+i+”[^\\]]*?\\].*?\\[\\/”+i+”\\]”,a=e.match(new RegExp(o,”g”))||[];t=t.concat(a)}return t},le.prototype.matchNonCapturingShortcodes=function(e){return e.match(this.nonCaptureRegex)||[]},le.prototype.parseShortcodes=function(e,t){return”function”!=typeof t?(console.error(“Failed to parse shortcodes. Expected parameter to be a function, instead received “+se()(t)),!1):”object”===se()(e)&&e.length>0?void jQuery.post(ajaxurl,{action:”wpseo_filter_shortcodes”,_wpnonce:wpseoScriptData.analysis.plugins.shortcodes.wpseo_filter_shortcodes_nonce,data:e},function(e){this.saveParsedShortcodes(e,t)}.bind(this)):t()},le.prototype.saveParsedShortcodes=function(e,t){e=JSON.parse(e);for(var n=0;n<e.length;n++)this.parsedShortcodes.push(e[n]);t()};var de=le,pe=n(254),fe=n.n(pe),ge=function(){function e(t,n){f()(this,e),this._registerPlugin=t,this._registerModification=n}return h()(e,[{key:”register”,value:function(){this._registerPlugin(“YoastMarkdownPlugin”,{status:”ready”}),this._registerModification(“content”,this.parseMarkdown.bind(this),”YoastMarkdownPlugin”,1)}},{key:”parseMarkdown”,value:function(e){return fe()(e)}}]),e}(),he=n(38),me=n(123),be=n(151),ye=n(167),we=jQuery;function Oe(e,t){return wpseoScriptData.metabox.publish_box.labels[e][t]||””}function ve(e,t){var n=we(“#”+e+”-score”),r=”image yoast-logo svg “+t;n.children(“.image”).attr(“class”,r);var i=Oe(e,t);n.children(“.score-text”).html(i)}function _e(e,t){var n=we(“<div />”,{class:”misc-pub-section yoast yoast-seo-score “+e+”-score”,id:e+”-score”}),r=we(“<span />”,{class:”score-text”,html:Oe(e,t)}),i=we(“<span>”).attr(“class”,”image yoast-logo svg na”);n.append(i).append(r),we(“#yoast-seo-publishbox-section”).prepend(n)}function Ee(e){var t=we(“#wpadminbar”),n=we(e);if(t&&n){var r=”fixed”===t.css(“position”)?t.height():0;we([document.documentElement,document.body]).animate({scrollTop:n.offset().top-r},1e3),n.focus(),0===n.parent().siblings().length&&n.click()}}function Se(){wpseoScriptData.metabox.keywordAnalysisActive&&_e(“keyword”,”na”),wpseoScriptData.metabox.contentAnalysisActive&&_e(“content”,”na”),we(“#content-score”).on(“click”,”[href=’#yoast-readability-analysis-collapsible-metabox’]”,(function(e){e.preventDefault(),document.querySelector(“#wpseo-meta-tab-readability”).click(),Ee(“#wpseo-meta-section-readability”)})),we(“#keyword-score”).on(“click”,”[href=’#yoast-seo-analysis-collapsible-metabox’]”,(function(e){e.preventDefault(),Ee(“#yoast-seo-analysis-collapsible-metabox”)}))}String.prototype.ucfirst=function(){return this.charAt(0).toUpperCase()+this.substr(1)};var je=n(109),Te=n(105),ke=n(118),xe=n(86),Pe=n(188),De=n(10),Ae=n.n(De),Re=n(71),Ie=n(227),Ce=n.n(Ie),Me=n(97),Ne=n(42),Le=n(55);function Ue(e,t){var n=Object.keys(e);if(Object.getOwnPropertySymbols){var r=Object.getOwnPropertySymbols(e);t&&(r=r.filter((function(t){return Object.getOwnPropertyDescriptor(e,t).enumerable}))),n.push.apply(n,r)}return n}function Fe(e){for(var t=1;t<arguments.length;t++){var n=null!=arguments[t]?arguments[t]:{};t%2?Ue(Object(n),!0).forEach((function(t){Ae()(e,t,n[t])})):Object.getOwnPropertyDescriptors?Object.defineProperties(e,Object.getOwnPropertyDescriptors(n)):Ue(Object(n)).forEach((function(t){Object.defineProperty(e,t,Object.getOwnPropertyDescriptor(n,t))}))}return e}var Be,Ye,Ke=he.tmceId,Ve=jQuery,qe=(Be=Object(Me.a)(),Ye=new Ce.a(Be),Object(j.isEmpty)(Be)&&(Ye=new Ce.a({domain:”js-text-analysis”,locale_data:{“js-text-analysis”:{“”:{}}}})),Ye),We=function(e){“object”===(“undefined”==typeof CKEDITOR?”undefined”:se()(CKEDITOR))&&console.warn(“YoastSEO currently doesn’t support ckEditor. The content analysis currently only works with the HTML editor or TinyMCE.”),this._data=e.data,this._store=e.store};We.prototype.getData=function(){var e=this._data.getData(),t=this._store.getState(),n={keyword:Object(Le.a)()?this.getKeyword():””,meta:this.getMeta(),text:e.content,title:e.title,url:e.slug,excerpt:e.excerpt,snippetTitle:this.getSnippetTitle(),snippetMeta:this.getSnippetMeta(),snippetCite:this.getSnippetCite(),primaryCategory:this.getPrimaryCategory(),searchUrl:this.getSearchUrl(),postUrl:this.getPostUrl(),permalink:this.getPermalink(),titleWidth:Object(Re.a)(this.getSnippetTitle())},r={metaTitle:Object(j.get)(t,[“analysisData”,”snippet”,”title”],this.getSnippetTitle()),url:Object(j.get)(t,[“snippetEditor”,”data”,”slug”],e.slug),meta:this.getMetaDescForAnalysis(t)};return Fe(Fe({},n),r)},We.prototype.getKeyword=function(){return document.getElementById(“yoast_wpseo_focuskw”)&&document.getElementById(“yoast_wpseo_focuskw”).value||””},We.prototype.getMetaDescForAnalysis=function(e){var t=Object(j.get)(e,[“analysisData”,”snippet”,”description”],this.getSnippetMeta());return””!==wpseoScriptData.metabox.metaDescriptionDate&&(t=wpseoScriptData.metabox.metaDescriptionDate+” – “+t),t},We.prototype.getMeta=function(){return document.getElementById(“yoast_wpseo_metadesc”)&&document.getElementById(“yoast_wpseo_metadesc”).value||””},We.prototype.getText=function(){return ne.markers.removeMarks(he.getContentTinyMce(Ke))},We.prototype.getTitle=function(){return document.getElementById(“title”)&&document.getElementById(“title”).value||””},We.prototype.getUrl=function(){var e=Object(S.select)(“core/editor”);if(e)return e.getCurrentPostAttribute(“slug”);var t=””,n=Ve(“#new-post-slug”);return 0<n.length?t=n.val():null!==document.getElementById(“editable-post-name-full”)&&(t=document.getElementById(“editable-post-name-full”).textContent),t},We.prototype.getExcerpt=function(){var e=””;return null!==document.getElementById(“excerpt”)&&(e=document.getElementById(“excerpt”)&&document.getElementById(“excerpt”).value||””),e},We.prototype.getSnippetTitle=function(){return document.getElementById(“yoast_wpseo_title”)&&document.getElementById(“yoast_wpseo_title”).value||””},We.prototype.getSnippetMeta=function(){return document.getElementById(“yoast_wpseo_metadesc”)&&document.getElementById(“yoast_wpseo_metadesc”).value||””},We.prototype.getSnippetCite=function(){return this.getUrl()||””},We.prototype.getPrimaryCategory=function(){var e=””,t=Ve(“#category-all”).find(“ul.categorychecklist”),n=t.find(“li input:checked”);if(1===n.length)return this.getCategoryName(n.parent());var r=t.find(“.wpseo-primary-term > label”);return r.length?e=this.getCategoryName(r):e},We.prototype.getSearchUrl=function(){return wpseoScriptData.metabox.search_url},We.prototype.getPostUrl=function(){return wpseoScriptData.metabox.post_edit_url},We.prototype.getPermalink=function(){var e=this.getUrl();return wpseoScriptData.metabox.base_url+e},We.prototype.getCategoryName=function(e){var t=e.clone();return t.children().remove(),Ve.trim(t.text())},We.prototype.setDataFromSnippet=function(e,t){switch(t){case”snippet_meta”:document.getElementById(“yoast_wpseo_metadesc”).value=e;break;case”snippet_cite”:if(this.leavePostNameUntouched)return void(this.leavePostNameUntouched=!1);null!==document.getElementById(“post_name”)&&(document.getElementById(“post_name”).value=e),null!==document.getElementById(“editable-post-name”)&&null!==document.getElementById(“editable-post-name-full”)&&(document.getElementById(“editable-post-name”).textContent=e,document.getElementById(“editable-post-name-full”).textContent=e);break;case”snippet_title”:document.getElementById(“yoast_wpseo_title”).value=e}},We.prototype.saveSnippetData=function(e){this.setDataFromSnippet(e.title,”snippet_title”),this.setDataFromSnippet(e.urlPath,”snippet_cite”),this.setDataFromSnippet(e.metaDesc,”snippet_meta”)},We.prototype.bindElementEvents=function(e){this.inputElementEventBinder(e),this.changeElementEventBinder(e)},We.prototype.changeElementEventBinder=function(e){for(var t=[“#yoast-wpseo-primary-category”,’.categorychecklist input[name=”post_category[]”]’],n=0;n<t.length;n++)Ve(t[n]).on(“change”,e)},We.prototype.inputElementEventBinder=function(e){for(var t=[“excerpt”,”content”,”title”],n=0;n<t.length;n++)null!==document.getElementById(t[n])&&document.getElementById(t[n]).addEventListener(“input”,e);he.tinyMceEventBinder(e,Ke)},We.prototype.saveScores=function(e,t){var n=Object(Ne.a)(e);ve(“content”,n.className),document.getElementById(“yoast_wpseo_linkdex”).value=e,””===t&&(n.className=”na”,n.screenReaderText=qe.dgettext(“js-text-analysis”,”Enter a focus keyphrase to calculate the SEO score”)),Object(je.a)(n),Object(Te.a)(n),ve(“keyword”,n.className),jQuery(window).trigger(“YoastSEO:numericScore”,e)},We.prototype.saveContentScore=function(e){var t=Object(Ne.a)(e);ve(“content”,t.className),Object(Le.a)()||(Object(je.a)(t),Object(Te.a)(t)),Ve(“#yoast_wpseo_content_score”).val(e)};var ze=We,$e=n(65),Ge=n(106),He=n(189),Qe=n(178),Ze=n(104),Xe=n(72),Je=n(190),et=n(60),tt=n(45),nt=n(17),rt=n(61),it=n(59);function ot(e,t,n){if(“undefined”!=typeof wpseoScriptData){var i,o,a,s,c,u=new He.a;jQuery(document).on(“ajaxComplete”,(function(e,n,r){if(“/admin-ajax.php”===r.url.substr(0-“/admin-ajax.php”.length)&&”string”==typeof r.data&&-1!==r.data.indexOf(“action=sample-permalink”)){s.leavePostNameUntouched=!0;var i={slug:l(n)};t.dispatch(Object(nt.k)(i))}})),function(){var c,l,h,m;if(i=e(“#wpseo_meta”),he.setStore(t),he.wpTextViewOnInitCheck(),(c=new me.a).isClassicEditorHidden()&&he.disableMarkerButtons(),c.vcActive?he.disableMarkerButtons():c.listen({classicEditorHidden:function(){he.disableMarkerButtons()},classicEditorShown:function(){he.isTextViewActive()||he.enableMarkerButtons()}}),0!==i.length){s=function(e){var n=new ze({data:e,store:t});return n.leavePostNameUntouched=!1,n}(n),Se();var b=function(t){!function(e){(void 0===window.tinyMCE||Object(ee.a)()||”1″!==wpseoScriptData.metabox.show_markers)&&e.dispatch(Object(tt.b)(“disabled”))}(t);var n,r={elementTarget:[he.tmceId,”yoast_wpseo_focuskw_text_input”,”yoast_wpseo_metadesc”,”excerpt”,”editable-post-name”,”editable-post-name-full”],targets:(n={},Object(Le.a)()&&(n.output=”does-not-really-exist-but-it-needs-something”),Object($e.a)()&&(n.contentOutput=”also-does-not-really-exist-but-it-needs-something”),n),callbacks:{getData:s.getData.bind(s)},locale:wpseoScriptData.metabox.contentLocale,marker:Object(Qe.a)(t),contentAnalysisActive:Object($e.a)(),keywordAnalysisActive:Object(Le.a)(),hasSnippetPreview:!1,debouncedRefresh:!1,researcher:new window.yoast.Researcher.default};Object(Le.a)()&&(t.dispatch(Object(et.d)(e(“#yoast_wpseo_focuskw”).val())),r.callbacks.saveScores=s.saveScores.bind(s),r.callbacks.updatedKeywordsResults=function(e){var n=t.getState().focusKeyword;t.dispatch(Object(re.setSeoResultsForKeyword)(n,e)),t.dispatch(Object(nt.h)())}),Object($e.a)()&&(r.callbacks.saveContentScore=s.saveContentScore.bind(s),r.callbacks.updatedContentResults=function(e){t.dispatch(Object(re.setReadabilityResults)(e)),t.dispatch(Object(nt.h)())}),o=e(“#title”);var i=Object(Me.a)();return Object(j.isUndefined)(i)||Object(j.isUndefined)(i.domain)||(r.translations=i),r}(t);a=new ne.App(b),window.YoastSEO=window.YoastSEO||{},window.YoastSEO.app=a,window.YoastSEO.store=t,window.YoastSEO.analysis={},window.YoastSEO.analysis.worker=Object(ke.a)(),window.YoastSEO.analysis.collectData=function(){return Object(Pe.a)(n,t,u,a.pluggable,Object(S.select)(“core/block-editor”))},window.YoastSEO.analysis.applyMarks=function(e,t){return Object(Qe.a)()(e,t)},window.YoastSEO.app.refresh=Object(j.debounce)((function(){return Object(xe.default)(window.YoastSEO.analysis.worker,window.YoastSEO.analysis.collectData,window.YoastSEO.analysis.applyMarks,t,s)}),Ze.refreshDelay),window.YoastSEO.app.registerCustomDataCallback=u.register,window.YoastSEO.app.pluggable=new be.a(window.YoastSEO.app.refresh),window.YoastSEO.app.registerPlugin=window.YoastSEO.app.pluggable._registerPlugin,window.YoastSEO.app.pluginReady=window.YoastSEO.app.pluggable._ready,window.YoastSEO.app.pluginReloaded=window.YoastSEO.app.pluggable._reloaded,window.YoastSEO.app.registerModification=window.YoastSEO.app.pluggable._registerModification,window.YoastSEO.app.registerAssessment=function(e,t,n){if(!Object(j.isUndefined)(a.seoAssessor))return window.YoastSEO.app.pluggable._registerAssessment(a.defaultSeoAssessor,e,t,n)&&window.YoastSEO.app.pluggable._registerAssessment(a.cornerStoneSeoAssessor,e,t,n)},window.YoastSEO.app.changeAssessorOptions=function(e){window.YoastSEO.analysis.worker.initialize(e).catch(Xe.a),window.YoastSEO.app.refresh()},Object(Je.a)(a.refresh,”get_focus_keyword_usage”,t),t.subscribe(p.bind(null,t,a.refresh)),window.YoastSEO.analyzerArgs=b,window.YoastSEO.wp={},window.YoastSEO.wp.replaceVarsPlugin=new oe.a(a,t),window.YoastSEO.wp.shortcodePlugin=new de({registerPlugin:a.registerPlugin,registerModification:a.registerModification,pluginReady:a.pluginReady,pluginReloaded:a.pluginReloaded}),wpseoScriptData.metabox.markdownEnabled&&new ge(a.registerPlugin,a.registerModification).register(),window.YoastSEO.wp._tinyMCEHelper=he,Object(Le.a)()&&(l=r,h=e(“#yoast_wpseo_linkdex”).val(),m=Object(Ne.a)(h),Object(je.a)(m),Object(Te.a)(m),l.updateScore(“keyword”,m.className)),Object($e.a)()&&function(t){var n=e(“#yoast_wpseo_content_score”).val(),r=Object(Ne.a)(n);Object(Te.a)(r),t.updateScore(“content”,r.className)}(r),window.YoastSEO.analysis.worker.initialize(Object(ke.b)()).then((function(){jQuery(window).trigger(“YoastSEO:ready”)})).catch(Xe.a),s.bindElementEvents(Object(j.debounce)((function(){return Object(xe.default)(window.YoastSEO.analysis.worker,window.YoastSEO.analysis.collectData,window.YoastSEO.analysis.applyMarks,t,s)}),Ze.refreshDelay)),d(a);var y=a.initAssessorPresenters.bind(a);a.initAssessorPresenters=function(){y(),d(a)},n.setRefresh&&n.setRefresh(a.refresh);var w=Ge.a.getDataFromCollector(s),O=Ge.a.getTemplatesFromL10n(wpseoScriptData.metabox);w=Ge.a.getDataWithTemplates(w,O),t.dispatch(Object(nt.k)(w)),t.dispatch(Object(it.e)(“1″===document.getElementById(“yoast_wpseo_is_cornerstone”).value));var v=t.getState().focusKeyword;Object(ye.a)(window.YoastSEO.analysis.worker.runResearch,t,v);var _=Object(j.debounce)((function(){a.refresh()}),50),E=null;if(t.subscribe((function(){var n=t.getState().focusKeyword;v!==n&&(v=n,Object(ye.a)(window.YoastSEO.analysis.worker.runResearch,t,v),e(“#yoast_wpseo_focuskw”).val(v),_());var r=Ge.a.getDataFromStore(t),i=Ge.a.getDataWithoutTemplates(r,O);w.title!==r.title&&s.setDataFromSnippet(i.title,”snippet_title”),w.slug!==r.slug&&s.setDataFromSnippet(i.slug,”snippet_cite”),w.description!==r.description&&s.setDataFromSnippet(i.description,”snippet_meta”);var o=t.getState();E!==o.isCornerstone&&(E=o.isCornerstone,document.getElementById(“yoast_wpseo_is_cornerstone”).value=o.isCornerstone,a.changeAssessorOptions({useCornerstone:o.isCornerstone})),w.title=r.title,w.slug=r.slug,w.description=r.description})),Object(ee.a)()){var T=g();f(T,t),Object(S.subscribe)((function(){var e=g();e!==T&&f(T=e,t)}))}Object(xe.initializationDone)(),window.YoastSEO.app.refresh()}}()}function l(e){return””===e.responseText?o.val():jQuery(“<div>”+e.responseText+”</div>”).find(“#editable-post-name-full”).text()}function d(e){Object(j.isUndefined)(e.seoAssessorPresenter)||(e.seoAssessorPresenter.render=function(){}),Object(j.isUndefined)(e.contentAssessorPresenter)||(e.contentAssessorPresenter.render=function(){},e.contentAssessorPresenter.renderIndividualRatings=function(){})}function p(e,t){var n=c||””;c=e.getState().analysisData.snippet,!Object(ie.isShallowEqualObjects)(n,c)&&t()}function f(e,t){“visual”!==e?t.dispatch(Object(tt.b)(“disabled”)):t.dispatch(Object(tt.b)(“enabled”))}function g(){return Object(S.select)(“core/edit-post”).getEditorMode()}}Object(rt.setYoastComponentsL10n)(),Object(rt.setWordPressSeoL10n)(),window.YoastReplaceVarPlugin=oe.a,window.YoastShortcodePlugin=de;var at=n(80),st=n.n(at);var ct=n(154),ut=n(155),lt=n(191),dt=n(185);window.wpseoPostScraperL10n=window.wpseoScriptData.metabox,window.wpseoShortcodePluginL10n=window.wpseoScriptData.analysis.plugins.shortcodes,window.YoastSEO=window.YoastSEO||{},a()((function(){Object(u.a)(c.a),”undefined”!=typeof wpseoPrimaryCategoryL10n&&te(c.a);var e=Object(lt.a)();window.yoast.initEditorIntegration(e);var t=new window.yoast.EditorData((function(){}),e);t.initialize(window.wpseoScriptData.analysis.plugins.replaceVars.replace_vars),ot(c.a,e,t),window.wpseoScriptData&&void 0!==window.wpseoScriptData.featuredImage&&function(e){var t,n,r,i=function(e){this._app=e,this.featuredImage=null,this.pluginName=”addFeaturedImagePlugin”,this.registerPlugin(),this.registerModifications()};function o(){e(“#yst_opengraph_image_warning”).remove(),n.removeClass(“yoast-opengraph-image-notice”)}i.prototype.setFeaturedImage=function(e){this.featuredImage=e,this._app.pluginReloaded(this.pluginName)},i.prototype.removeFeaturedImage=function(){this.setFeaturedImage(null)},i.prototype.registerPlugin=function(){this._app.registerPlugin(this.pluginName,{status:”ready”})},i.prototype.registerModifications=function(){this._app.registerModification(“content”,this.addImageToContent.bind(this),this.pluginName,10)},i.prototype.addImageToContent=function(e){return null!==this.featuredImage&&(e+=this.featuredImage),e};var a,s,c=wp.media.featuredImage.frame();”undefined”!=typeof YoastSEO&&(t=new i(YoastSEO.app),n=e(“#postimagediv”),r=n.find(“.hndle”),c.on(“select”,(function(){var i,a,s;!function(t){var i=t.state().get(“selection”).first().toJSON();i.width<200||i.height<200?0===e(“#yst_opengraph_image_warning”).length&&(e(‘<div id=”yst_opengraph_image_warning” class=”notice notice-error notice-alt”><p>’+wpseoScriptData.featuredImage.featured_image_notice+”</p></div>”).insertAfter(r),n.addClass(“yoast-opengraph-image-notice”),st()(wpseoScriptData.featuredImage.featured_image_notice,”assertive”)):o()}(c),s=(a=c.state().get(“selection”).first()).get(“alt”),i=’‘,t.setFeaturedImage(i)})),n.on(“click”,”#remove-post-thumbnail”,(function(){t.removeFeaturedImage(),o()})),void 0!==e(“#set-post-thumbnail > img”).prop(“src”)&&t.setFeaturedImage(e(“#set-post-thumbnail “).html()),Object(ee.a)()&&Object(S.subscribe)((function(){var e=Object(S.select)(“core/editor”).getEditedPostAttribute(“featured_media”);if(function(e){return”number”==typeof e&&e>0}(e)&&void 0!==(a=Object(S.select)(“core”).getMedia(e))&&a!==s){s=a;var n=’
‘);t.setFeaturedImage(n)}})))}(c.a),Object(ct.a)(c.a),Object(ut.a)(c.a),setTimeout(dt.a,500)}))}]);
There is a plugin conflict between some plugins you have installed, deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If the problem is still there, then please make a full backup, send an email at contact@tagdiv.com and provide wp-admin and Cpanel access, so we can investigate this issue and let you know what can be done. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
