Problem with Yoast Snippet editor on the HP
I just installed your theme.
There is a problem on the home page, with Yoast Snippet editor:
1. I can not change the title tag
2. There is a strange URL in the snippet : instead of http://www.travailler-en-angleterre.com, th url is http://www.travailler-en-angleterre.com/example-post
The problem is only for the homepage (www.travailler-en-angleterre.com).
I use VC ans Yoast with lots of other theme, without any problem.
Did you have any existing problem like this? Any hints?
Many thanks in advance
David
Hello dtalerman,
1)Unfortunately, the title tags can not be changed from the Theme panel or from some editors but only from the code.
2)Please try to disable all the active plugins, except Visual Composer and SEO Yoast, clears all cache and install only the plugins that come bundled with our theme. SEO YOAST is tested with our theme and should work as expected. If you are using some untested plugins, these could cause some interference between SEO Yoast and our theme and gives some error.
Hope this helps!
If is not what you mean, and you need more assistance in this regard, please provide more details about your problem so I will be able to provide a more accurate response. Also, some screenshots with your issue would be more useful for a good understanding.
Thank you for the message!
