Problem with youtube playlist module
i am having a problem with the youtube playlist modulo because i dont know why when i try to use one on my homepage everything disapire and i am unable to make it work.
please help.
Hello Mario635,
Please ensure that you are using the latest version of the theme (Newspaper 7.1.1) with the required plugins (Visual Composer 4.11.2 and Social Counter 4.1). Also, if you are using some untested plugins with our theme, please try to disable them and leave just Visual Composer to active and install only the plugins that come bundled withy our theme and rule out the conflicting plugins. Also, before achieving best results, please ensure that you have increased all the parameters from your System Status according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Please notice that the Youtube Playlist is fully tested with the theme and is working fine. I have tested on my side and everything seems to work as properly.
