the tagDiv social counter plugin dont allow me to use my youtube channel link
its only work with user channel like
http://www.youtube.com/user/anything
How to make it work with channel ?
http://www.youtube.com/channel/anything
This topic was modified 11 years by
Lewis.
If you use the latest theme version and also you have updated the Social Counter plugin to version 2.10 the channel also will work if you add it like this – http://screencast.com/t/kwEAA8Cb
Unfortunately we did not tested new version of Social Counter with older versions of the theme, so you will have to update it. Another solution will be to make this change in the social counter file to work only with channel – https://forum.tagdiv.com/topic/problem-with-tagdiv-social-counter-youtube/#post-38128
Unfortunately I cannot make any suggestion it should work. We use the latest version of the theme and also theme’s plugins updated to help our customers. I suggest to update the theme and also the plugin and it should work fine, I also tested your channel and it display subscribers – http://screencast.com/t/Si3op2j3 – http://screencast.com/t/PsE9jFKYsBiY
