Problem witn logo in mobile horizontal
Hi i have a problem with logo when i go mobile on horizontale i cant see T- TELEGRAF IS LOGO ! But T is white in white color .When i refresh in horizontal position then i see for second T and then T is turin off , Can u help me to fix this problem,,
When u go on mobile in telegraf.si u must to click on one post then u turn to mobile on horizontale,, i will se just ELEGRAF- RED COLOUR,, THEN U REFRESH U SEE just 1 second WHITE T and then is disapere.
Regards
Zdenko
https://telegraf.si/
If you have a responsive version of your website which is looking similar like on desktop, then you need to deactivate Mobile Theme, then please edit the page with TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB and there you can see your mobile version. Take a look also for horizontal mode for tablets viewport and see if there are some changes.
Hope that helps you!
Hi again,
Yes i do all and upload all telefraf logoes,, but when i click on post then then i go to horizontal i see logo without T .. and on tablet is the same problem
PROBLEM LOGO
VIDEO
If you changed the design there and the problem is still there, then the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Ok ty ,, done. i was change black backgroung and now is ok.
Ty for good support
Regards
Zdenko
