Hola, Cuando realizo una búsqueda desde la home en la barra superior en el botón de la lupa, antes al buscar una palabra me aparecía ordenado por fecha y ahora es totalemente aleatorio, podrían ayudarme? Quiero que aparezca por orden de fecha.
I just checked teh mentioned situation and it appears that now it is working correctly, the results are sorted after the latest – https://i.imgur.com/4zkNLLy.png
For me, the results are still correct – https://i.imgur.com/EKwdEgk.png https://i.imgur.com/0LXaDLB.png Maybe you have some cache in your browser or something extra interfering, please check in incognito.
Me he dado cuenta que solo aparecen si la palabrá “olfer” está en el título. Hay alguna forma de que también aparezca el artículo si la palabra clave “olfer” está en el texto del artículo y no en el título?
Por ejemplo: https://www.redeweb.com/featured/serie-xtr-fuentes-de-alimentacion-trifasicas-de-carril-din/
This is how the search works: it searches first in the post title and then in the post content. The result you mentioned is included in the search results, but it does not appear on the first results page it is displayed on the second page of the search results. https://i.imgur.com/MTIY4oU.png
Hey,
I get what you mean! Unfortunately, there’s no option to do exactly that. Right now, search results first show posts that have the word in the title, sorted by latest, and then it shows posts where the word is in the content, also sorted by latest.
I understand you’d like all results to be mixed together and sorted purely by date, regardless of whether the word is in the title or content. Sadly, that’s not possible right now.
The reason it works this way is that matches in the title are considered more relevant, while matches in the content might just mention the word in passing and could be about something else.
