Problema Disqus
Multumesc, o sa ma uit prin ele sa vad ce reusesc sa fac.
Am totusi o intrebare legata de compatibilitatea AMP.
Am incercat sa activez tema AMP + cea mobila, insa in verificarea Google pentru AMP imi spune ca am un script boilerplate de prea multe ori in pagina.
Daca folosesc AMP fara tema voastra, e ok, nu afiseaza vreo eroare.
There are a few cases when there could be such errors. The most common one is happening due to the Facebook pixel code or plugin – https://forum.tagdiv.com/topic/amp-errors-6/
It can also be caused by optimization plugins, as in this case
– https://forum.tagdiv.com/topic/fix-for-autoptimize-aggregate-css-files-breaking-amp/
Multumesc.
Tot legat de tema mobila. Cum pot adauga block-uri pe prima pagina(nu am pagina statica) ? Pe tema standard folosesc shortcode-urile intr-o functie php, dar pe tema mobila nu le ruleaza.
Merci.
Glad I can help.
The mobile theme won’t work with composer content, only what is possible through the simple mobile editor. So displaying a block on phones when the mobile theme is active is not possible. You can check how the mobile theme looks by visiting this demo with a phone or with a browser emulator – https://demo.tagdiv.com/newspaper_local_news/
However we introduced in he latest update a setting which can now be used to disable the mobile theme per page or post. So for example the homepage on mobile can be made to not use the mobile theme and will display the content from desktop, while the rest of the website will. This was a much requested feature, now it is possible.
The setting is found in the page/post edit screen in Gutenberg – http://prntscr.com/oisnlc
Please let me know if you have more questions.
Viewing 4 posts - 26 through 29 (of 29 total)
