Probleme avec la météo
Bonjour,
Lorsque je rentre ma ville ou ma localisation dans l’espace “weather” de mon site je tombe à chaque fois sur la météo de connaught place. Que faire ?
Merci d’avance, cordialement,
Hello Goa,
Please ensure that you are using the latest theme version and try to add again the Weather Widget on your website. I have tested on my side and it seems to work as expected. Notice that when you press the locate button, you will have to manually introduce your location.
Bonjour,
Le problème persiste, êtes vous disponible pour un partage d’écran sur Skype sinon ?
Please try as a test to disable all your plugins except Visual composer, clear any caching installed on your website the check if the weather widget is working properly. I have tested the widget also, but there are no problems with it. Maybe you have a plugin that could be causing this, or modifications to the theme.
