Problème avec le méga menu
Bonjour,
Je me permet de vous contacter car je n’arrive pas à réaliser le mega menu sur mon site. Je ne vois pas les options à cocher dans le menu.
Merci d’avance, cordialement,
There is a guide that you can use to create a mega-menu for your website
– https://forum.tagdiv.com/mega-menu/
Please follow the steps that are mentioned, and you will be able to create a mega-menu. If you have a different problem, please provide more details and some screenshots if needed so we can better understand the issue.
Bonjour,
Je n’ai pas l’option “Mega Menu” 😡
View post on imgur.com
Please deactivate all your plugins except the ones that are provided with the theme, and clear any cache that you have installed. In most cases a plugin or plugin conflict can cause this kind of problems. If after trying this the option is present, activate your plugins one by one and maybe identify the one responsible.
